Firmware Issue
jfink1
Firmware Issue
Post by jfink1 » Mon Apr 18, 2016 11:07 am
I have assembledthe i3 pro B printer and only see two black bars on LCD. Driver is installed.
I have tried to reload firmware as per advice on this forum but get error in Arduino program "cannot connect to programmer" or "time out"
I am able to connect to the printer using reptier host but no part of the printer will move or heat up.
Re: Firmware Issue
Post by Mark » Tue Apr 19, 2016 6:08 pm
Is your power supply have a 12V output? and the timeout thing, you might need to check out this link:
http://www.geeetech.com/forum/viewtopic ... 20&t=17102
jfink1
Re: Firmware Issue
Post by jfink1 » Fri Apr 22, 2016 7:34 am
Mark,
Power supply has 12v.
I tried everything to fix timeout but nothing has worked.
What is the next thing to check?
jfink1
Re: Firmware Issue
Post by jfink1 » Sat Apr 23, 2016 7:15 pm
Mark,
I am not having luck by removing all of the wires, pressing reset button, etc.
The crystal oscilator does not appear to be damaged, how do I check it?
Re: Firmware Issue
Post by Mark » Mon Apr 25, 2016 3:53 pm
Then I think you need to contact the sales to talk about this, the mainboard might be defective.
