i suppose so but even with the setting you gave me, the combined 2+2 squares, when are printed with pla all is ok, when printer starts with abs, the 2nd nozzle starts leaving the filaments but "hits/removes" the previous filament left on the heatbed.
eplained as above: black nozzle leaves the pla but red nozzle for the abs (red) starts printing as NO black filament was left on the heatbed (i think the printer should try somehow to avoid the black filament as it knows the black filament was just set there) and moves/damages/removes the black filament from the heatbed.
maybe will help a photo to explIain what i mean?
Thanks for any help!
also, i found that glue, maybe is a correct kind to try with 3dprinter?
http://bostik.it/images/made/images/upl ... 90_290.JPG
thanks again!
Mini G2s 2extruder NO filament and Spider DROP
Re: Mini G2s 2extruder NO filament and Spider DROP
GLUE specs:
humidity resistance: good/Buona
temp resistance: Da -40°C a +95°C
chemical resistance: good/Buona
I wonder use two different filaments, are they stick to each other well? if not maybe be when printing the second one will remove the previous filament as you said. And the glue, don't know it's gonna work or not..
