Z axis problem
Z axis problem
My z axis motors will turn with out rods in them but with both rods on will not turn could it possibly be entered slightly or is there another problom help please
Re: Z axis problem
Did you assembled the Z axis straight and the same height? and the rods, do they bending or not?
perhaps you can check this link here for point 2:
http://www.geeetech.com/forum/viewtopic ... 13&t=17038
Re: Z axis problem
Rods are straight used level and measuring caliper nothing bends evrything is plugged in properly I don't understand what's wrong
Re: Z axis problem
so how's the voltage of your motor driver? could it a little low?
and maybe you can post some pictures here to check it.
Re: Z axis problem
Here is the pic help please also I don't understand code
