Hello guys, I have a Geeetech gt2560 and the heated bed is not heating at all. I plugged the heated bed into the extruder hotend power slot and the heated bed works.
Is there any way I can use the second extruder power plug for the heated bed? Or any other way to fix it?
Thank you,
heated bed not heating
Re: heated bed not heating
maybe your mosfet for hotbed is dead, you can check this link here first:
http://www.geeetech.com/forum/viewtopic ... 13&t=17039
Thanks Mark, it was the fuse. A big issue to get that fuse over here.
then you can contact the seller to get a new fuse.
the type of the fuse is as follows:
name specific type parameter
heater fuse , SMT 5*10 , 0154010.DRT , 10A/125V
hotbed fuse , SMT 5*10 , 0154015.DRT , 15A/125V
