Before I start does anybody know what the FR100% means that is on the LCD ?
There was almost no assembly required, basically just wired the power supply and LCD. I received a second extruder in a little bag. It says 3 (0.3) on the extra extruder. Now I am not sure what size the extruder is that is fitted to the machine. Reason being is that when i set the machine to print with an 0.2 it prints better (not nearly great) than with the 0.3 If it is standard with a .3 why send me an exra .3 loose in the box ?
I have tried all kinds of settings as you can see.
![Image](https://dl.dropboxusercontent.com/u/64909012/Print/all.jpg)
All prints with 0.3mm ends up looking like this :
![Image](https://dl.dropboxusercontent.com/u/64909012/Print/03side.jpg)
0.2 looks better layer wise :
![Image](https://dl.dropboxusercontent.com/u/64909012/Print/02.side.jpg)
but not that great from front :
![Image](https://dl.dropboxusercontent.com/u/64909012/Print/02%20front.jpg)
seems not all layers are bonded :
![Image](https://dl.dropboxusercontent.com/u/64909012/Print/02%20print.jpg)
Any Advice ?
