Purasa Dual Extruder not heating
clint3501
Post by clint3501 » Mon Dec 28, 2015 11:12 pm
A little assist requested.
I have i3 pro C dual extruder.
Under Manual Control I am able to heat the extruders and heat bed, filament flows.
However when I attempt to use the sample print provided the heat bed warms up however the extruders do not heat up at all. The print begins once the heatbed arrives at temp however since the extruders are not heated no print really takes place, everything is moving though.
A suggestion on what to look for would be appreciated.
(yes I went through the forum postings first and did not find anything that appears to answer my question since I think its not a hardware problem)
Mark
Re: Purasa Dual Extruder not heating
Post by Mark » Wed Dec 30, 2015 5:57 pm
how's the settings in your slic3r?
clint3501
Post by clint3501 » Wed Dec 30, 2015 8:08 pm
what settings do you want to see? If you direct me it will expedite the post exchange.
Mark
Post by Mark » Thu Dec 31, 2015 5:52 pm
such as the temperature settings in slic3r:
