A10T profile
Moderator: vert
ThomasGee
Re: A10T profile
Post by ThomasGee » Fri Dec 13, 2019 3:55 pm
is there a possibility to change the size aof the prime tower in curaengine in Repetier Host??
I experienced problems when there are more then one filament changes in a layer.
The tower is getting too high, so that the nozzle bumps into it an the print-bed sometimes slips.
Re: A10T profile
Post by William » Fri Dec 13, 2019 4:24 pm
Hi,The size of your model can be increased or decreased.
But the model itself is fixed.
Sardauker
Re: A10T profile
Post by Sardauker » Fri Dec 13, 2019 6:19 pm
Hi. How do I manage the filament purge with a bucket and change in Cura?
I can only rectract, not purge using the new filament.
Re: A10T profile
Post by William » Fri Dec 13, 2019 6:23 pm
Hi, You can pause printing in the printer and then replace the consumables;
Or select the corresponding extruder in the settings to print and slice.
Sardauker
Re: A10T profile
Post by Sardauker » Fri Dec 13, 2019 6:35 pm
Thanks but...
I'll Explain: I have a model that's made of 3 stl.
I can assign an extruder to each stl and print in 3 unfaded colors.
But if there's no purging the first trait of the new color in each strate will be faded with the previous.
I am asking: I am using I suppose a wrong g-code for the tool change. Is somewhere (i can't find it) a tool change Gcode to use a purge bucket with three extruders?
Thank you in advance.
ThomasGee
Re: A10T profile
Post by ThomasGee » Fri Dec 13, 2019 9:03 pm
Where can I change the size of the tower curaengine in Repetier Host??
Sardauker
Re: A10T profile
Post by Sardauker » Sat Dec 14, 2019 3:00 am
there's a "purge volume" in the cura settings that, increased, increased the size of my tower.
The only problem is that the extruder drags on the tower offsetting the print.
Geeeko
Re: A10T profile
Post by Geeeko » Sun Dec 15, 2019 9:26 am
@Sardauker,
Try a different position of the tower on the bed (x,y parameters).
Sardauker
Re: A10T profile
Post by Sardauker » Sun Dec 15, 2019 3:02 pm
Thanks.
Cura settings or Gcode?
ThomasGee
Re: A10T profile
Post by ThomasGee » Sun Dec 15, 2019 9:32 pm
Sorry, I can see in the settings of curaengine slicer (NOT CURA itself!) the possibility to change these pameters.
Only
Anmerkung 2019-12-15 143116.png (8.24 KiB) Viewed 375 times
