Layer shifting
Thegrinch
Layer shifting
Post by Thegrinch » Tue Apr 14, 2020 5:11 am
I’m getting problems with layer shifting.
I already tightened the belt.
Up the volts on the driver
Lower the volts on the driver
Lower jerk and acceleration
Tried another slicer program
Not sure what else to do.
Thegrinch
Re: Layer shifting
Post by Thegrinch » Tue Apr 14, 2020 5:12 am
The blue ones are with low voltage.
The black ones are with high voltage
Re: Layer shifting
Post by William » Tue Apr 14, 2020 10:10 am
Hi,it may be that the X-axis or Y-axis belt is loose, you can tighten it.
You can refer to the video https://www.youtube.com/watch?v=HHfhhqC9Fws
The voltage reference range is generally between 0.8-1.2
It may also be that the printing speed is too fast, you can appropriately reduce the printing speed.
Thegrinch
Re: Layer shifting
Post by Thegrinch » Fri Apr 17, 2020 4:36 am
i adjusted the voltage to 1.2 and still getting layer shifting.
i was looking at the tmc2208 you sell. it comes with heat sink.
The ones in mine right now dont have heat sink..
where they supposed to come with it ???
maybe they are getting too hot because they dont have heat sink ?
Re: Layer shifting
Post by William » Fri Apr 17, 2020 1:44 pm
Hi, you can check filament is free,a temporary problem with the filament not unspooling cleanly (a knot or tangles on the spool) might have blocked the movement of the (direct drive) extruder causing your 3D printer shifting layers.
You’ve got mechanical friction on this axis (the X-axis in this picture). Check if your printer moves freely along this axis, clean and lubricate the mechanical parts like smooth rods, lead-screws or rails and check for broken bearings.
Jteksler
Re: Layer shifting
Post by Jteksler » Wed Jun 03, 2020 8:29 am
Did anyone ever find a solution to this problem, I am having the same issue. Also could someone advise on how they changed the voltage and acceleration settings so I can mess with that myself.
Re: Layer shifting
Post by William » Wed Jun 03, 2020 9:47 am
the reasons:
1. The printing speed is too fast, reduce the printing speed, and control within a reasonable range.
2. The resistance of the XY axis is too large, lubricate the XY axis (lubricating oil, rail oil, or engine oil).
  3. The acceleration is too large, reduce the motor acceleration (general factory settings are generally no problem, adjusted in the screen).
4. The XY-axis timing belt is too slack, slipping and jumping teeth appear. Tension timing belt (no tooth skipping during operation)
TehZuCC
Re: Layer shifting
Post by TehZuCC » Wed Jul 08, 2020 3:48 am
I had the same Y-axis shifting issue. I had lowered my X and Y axis driver voltage because my Y axis driver blew out due to Geeetech not including heatsinks...thanks guys... :evil: :evil: :evil: :evil: :evil:
I adjusted the voltage back up to 1.25v once I had heatsinks and it solved the problem for me.
TehZuCC
Re: Layer shifting
Post by TehZuCC » Wed Jul 08, 2020 3:49 am
In order to adjust the voltage you need to adjust the screw on the driver. To measure the voltage probe the screw and the pin marked "gnd" on each chip, but be extremely careful not to short with another pin.
