I've had my A20T for 2 weeks and really find the instruction manual not much help, if I'm honest, so have come on here hoping for some guidance as to what I'm doing wrong. Really frustrated with this machine as 2 weeks in still not managed to successfully print anything of note yet.
I am having trouble getting the machine to print from one of the extruders, I think its called E2 in the manual - (its the one on the right as you are looking at the machine), E0 & E1 seem to be working ok. Could this be a problem with the heating element in the Extruder Head? Is there anything I could check to see if there is a blockage?
I have worked out how to change the filaments using the Prepare > Preheat PLA options and wait for it to say Change Filament then I can see the filament retract back up the tube to the extruder called E0 (although just to add to the confusion the display screen says E1). I have also worked out that I need to change the mixer settings (from 100%, 0%, 0%) to 0%, 0%, 100% to enable the filament change on E2. What I cannot seem to do is set the mixer setting to 0%, 100%, 0% to enable me to change the filament on E1 and have had to resort to setting the mixer to 50%,50%,0% so it retracts two filaments at the same time. Am I doing something wrong or missed something obvious to be able to set the mix as 0%,100%,0% - it seems a bit user un-friendly having to do all this and surely a better way would be to get to the Change Filament option and be able to select which out of E0, E1, E2 you would like to change.
Changing Filament problems
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
