About how to connect the 3d touch
Post by William » Wed Dec 04, 2019 11:53 am
Hi,guys
about how to connect the 3d touch in A20T.
3d touch 标准图.png (1.44 MiB) Viewed 20188 times
lmcmulle
Re: About how to connect the 3d touch
Post by lmcmulle » Sat Dec 07, 2019 12:19 am
Hi. @William you've posted 2 different sets of pictures with "how to connect 3d touch" one where the color sequence is (top to bottom) Brown/Red/Orange (this post) and the other with Orange/Red/Brown (in this post https://www.geeetech.com/forum/viewtopi ... 17&t=69659)
which is it?
Also do we need to update the firmware for it to work? if so where do we get that?
Leigh.
Post by William » Sat Dec 07, 2019 9:27 am
Hi,this connection is the same, 2pin is connected to the 2pin port;
3 pin is connected to the 3 pin port;
If you have 3d touch installed, you need to flash the firmware to 3d touch.
lmcmulle
Post by lmcmulle » Sat Dec 07, 2019 10:06 pm
@William,
each cable can go on 2 different ways, (the 2 pin cable can be installed black on top or white on top for example). are you saying the orrientation of the cables doesn't matter?
Post by William » Mon Dec 09, 2019 9:08 am
Hi, You can refer to the interpolation in the picture for connection
lmcmulle
Post by lmcmulle » Mon Dec 09, 2019 12:44 pm
Yes. And in the pictures above and in the other post on the topic you have it set up both ways, hence why I was asking. It’s a moot point at the moment because I can’t flash the printer for 3dTouch. We need to solve that first.
Post by William » Mon Dec 09, 2019 1:08 pm
Oh, sorry my falut.
you can refer to this post connect,
and can you tell me why you can't flash.
lmcmulle
Post by lmcmulle » Sun Dec 15, 2019 12:23 am
Oh, sorry my falut.
My printer doesn't seem to have a bootloader on it. I got a Uno to use as a programmer but I can't find the pins to connect now for the prorgamming interface for the GT2560 V4 board, can you show me that? Or can I get a replacement board that DOES have a bootloader on it? I don't want to have to return the printer to Amazon.
Post by William » Sun Dec 15, 2019 4:32 pm
Hi,If so, you can contact your sales person to replace the motherboard.
JAMac
Post by JAMac » Sat Dec 21, 2019 11:38 am
So, this is still not clear. The two cables can be plugged in either direction? Black and/or brown on top or bottom; any direction?
(Edit)
Never mind. It looks like the exact same pictures are used in the two posts. I'm not sure what Imcmulle is talking about. Brown and black are GND so they both go to the top.
