mise a jour firmware impossible?
CarsonGrey
Post by CarsonGrey » Thu Aug 27, 2020 3:13 pm
bonjour
j'ai donc un A20M , j'ai installé un 3dtouch mais impossible pour moi de transferer pour le 3d touch le firmware a la machine GT2560 V3
j'ai essayé sur 3 machines differentes Windows 10 , windows 7 ,mac mini ,3 cables usb differents ,
j'ai testé le fichier .hex avec omegle xender le logiciels firmware tool , j'ai tenté le marlin.ino sous arduino 1.8.5 mais toujours "avrdude stk500V2 timeout,
des que je lance le transfert la machine redemarre du coup le port com ne semble plus reconnu , la j'avoue que je ne sais plus trop quoi faire
si vous avez une idee
merci
Re: mise a jour firmware impossible?
Post by William » Thu Aug 27, 2020 4:47 pm
Hello, please check whether the development board, processor, and port of your firmware compiler are properly connected. If the above three items are connected correctly, there may be a problem with your motherboard serial port. :D
You can also refer to the link below for processing.
https://www.youtube.com/watch?v=8RkT924v6kc
robinjamess
Post by robinjamess » Sun May 23, 2021 5:32 am
bonjour
j'ai testé le fichier .hex avec le logiciels firmware tool , j'ai tenté le marlin.ino sous arduino 1.8.5 mais toujours "avrdude stk500V2 timeout,
TcsWebmail DadeSchools Upsers
merci
This error message appears while updating the Firmware of your Ultimaker 3. This could be due to a software or hardware failure. Please follow the steps outlined below to identify and resolve the issue.
Check the connection
In some cases, the problem is with a bad "physical" connection.
Make sure the Ultimaker is properly connected to the power cable and turned on when downloading the firmware.
For an Ultimaker 2, check if the USB cable is properly connected. Please use another USB cable to rule out USB cable failure.
Software
It is also possible that the connection failure is due to a bug in Cura or a problem with your computer or operating system. Indeed, it is mainly the old versions that are causing the problem. Therefore, check the following points:
First check that the latest version of Cura is installed on your computer.
Connect with a computer that has a different version of the operating system.
If the options described above do not work, there may be a problem with the main PCB. We invite you to contact our technical support by clicking on this link
ckmao01
Post by ckmao01 » Wed Jul 07, 2021 11:59 am
bonjour
merci
J'ai également rencontré le même problème la semaine dernière. Pour gagner du temps, j'ai appelé un centre de réparation.
Anyone can be a father, but it takes someone special to be a dad, and that's why I call you dad, because you are so special to me. You taught me the game and you taught me how to play it right.
Read more at fireboy and watergirl
