new motherboard question
LittleTrip
Post by LittleTrip » Wed Nov 06, 2019 10:55 am
i own a new A20M and i had to replace the motherboard do i need to download or upgrade this board before printing??? should it not come with software???
Re: new motherboard question
Post by William » Wed Nov 06, 2019 11:31 am
Hi, If you replace the motherboard, there is already the corresponding firmware on the motherboard.
Is the software you are referring to as slicing software?
If it is a slicing software, you can download it on your computer, you can use Repetier Host or Cura.
LittleTrip
Post by LittleTrip » Wed Nov 06, 2019 11:41 am
i was talking about the board itself
Post by William » Wed Nov 06, 2019 1:05 pm
Hi, I am not very clear what you are referring to,
the firmware is already on the motherboard.
What software are you referring to?
You can describe it in detail.
3DAngel
Post by 3DAngel » Thu Nov 07, 2019 9:25 am
The same board is used on different model of Geeetech printer.
So how the seller Will sent you the board for your printer model? Unless the seller told you and warranty you that they did the FW for your printer.
Otherwise, I would just flashbthwbFW with the right configuration for THE printer model you have.
LittleTrip
Post by LittleTrip » Thu Nov 07, 2019 10:51 am
im trying to find the firmware for the A20M with the new Gt2560 board if anyone knows a link that can help me that would be great
Post by William » Thu Nov 07, 2019 11:13 am
Hi, If you open the motherboard after installing it on the printer,
The screen does not display the A20M.
You can download it at this URL: viewtopic.php?f=20&t=17046
You can refer to this: viewtopic.php?f=20&t=17181
LittleTrip
Post by LittleTrip » Sat Nov 09, 2019 8:24 am
my A20M is almost good to go haha well i got the screen fixed it was the firmware missing a u8glib file i got a hold of someone from geeetech and they said sometimes the new boards will delete the u8glib files for some reason and that i needed to add it and when i did boom it worked hehe
but now i got a new problem :-( my print bed motor wont move all it does is jerk and i no its not the motor i tested it and it works fine if i plug it into the other slots so now im stuck again lol
by the time im done i should have replaced everything on this printer lol good thing for my anycubic lol
Post by William » Sat Nov 09, 2019 9:24 am
:D Hi, you can try to swap the motor wires for inspection to determine if the motor wires are broken and this happens.
If there is no problem with the motor cable,
you can try to swap the position of the motor cable on the motherboard to confirm if there is a problem with the motor wiring slot on the motherboard.
DzzD
Post by DzzD » Mon Nov 11, 2019 9:40 pm
Maybe check the Vref of the stepper motor driver, it could explain the jerk (not enough torque)
