![Smile :)](./images/smilies/icon_e_smile.gif)
I confirm: after update to new firmware every problem was solved. ![Smile :)](./images/smilies/icon_e_smile.gif)
You should use the latest RCBugFix-branch if you can. It has some changes done to the 3DTouch/BLTouch code that makes it work better.
ive followed the settings you have suggested but iu just cannot seem to get my printhead to go low enough, any other settings to check ?
Where I get the firmware for the Prusa I3 pro C dual extruder 3D and 3DTouch Auto Leveling Sensor
Because I do not come with the guidance and have no idea of programming
Would be nice if one can upload it
woher bekomme ich die firmware für den Prusa I3 pro C dual extruder 3D und 3DTouch Auto Leveling Sensor her
da ich mit der anleitung nicht klar kommme und keine ahnung von programmieren habe
wäre schön wenn einer es hochladen kann
Can some could give me the last firmware for the 3d touch sensor with GT2560 for my I3 Pro B please ? I hope you could help me? because Previous link on the forum doesn't work .....I thank you![Smile :)](./images/smilies/icon_e_smile.gif)
Hi to all.
I've a big issues with the abl. I use the modified firmware in the First post with reverse x axis and 400 valute for z Step.
Please look the video. https://youtu.be/p5Rg1tbQI2A
Someone help me, please
Loriz71:
You have changed your threaded rods so you are moving too slow for the probe.
Set DEFAULT_MAX_FEEDRATE to 4 for Z.
Also, you may need to set "#define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2)"
Thank you for your answer NiklasO.
Yesterday I've tested your marlin RCbugfix with similar problems.
Tonight I test your solution.
[edit]
Many thanks to NiklasO, all work fine after changing DEFAULT_MAX_FEEDRATE 2 to 4 for Z.
I've tested last NiklasO RcBugfix marlin and work fine
[edit]
I confirm with the great help of NiklasO, My prusa i3 Pro B acrylic works great with the 3d touch sensor and the firmrware is the last new![Smile :)](./images/smilies/icon_e_smile.gif)
I mount the 3dtouch sensor, then i calibrate the bed manual wih a sheet of paper to test the G29 with a good calibrated bed
This is the result of G28 and after a G29
![Image](https://scontent-mxp1-1.xx.fbcdn.net/v/t1.0-9/17903871_1730690893883701_865574210999485529_n.jpg?oh=5a4ca3d858473fddd69e234b3be65843&oe=59548A32)
But i just made a bed calibration, i suppose the difference between the 9 point in the real is near 0.1, if it is 1mm i can see it easy with a sheet of paper but it isn't.
Where is the problem?
