Wall layer becomes detached
I've just mov4ed from an XYZ printer to the A20 and am having issues with the wall layer that I haven't seen before.
They seem to be printed as single lines and don't bond to each other.
When the model cools the outer layer of the walls is loose and I have to cut it off.
I've tried increasing the overlap of infill but this didn't help
Has anyone else got this issue and a solution?
Re: Wall layer becomes detached
I encountered the same problem and have not found a reasonable solution, do you have a solution?
I found that if you start with a slow speed frist print layer, plus a higher hot bed, this will fix your issus,
let it do about 19 layers and then speed back up to 100%,
when it is warming up go to the tune setting and you can set it all up there
- Contact:
@mwc Thank you so much for really offering a solution to this problem, those who can't solve the problem will be grateful to you.
Had same issue
Remini
Remini
MX Player Apk is an app (APK) to catch all the entertainment pieces in one place. The topmost media player you can have on all your Android devices including PC, Mobile, Tablet, Smart TV, and so on.
