Resin VS Filament: Which Is Better for 3D Printing
Resin VS Filament: Which Is Better for 3D Printing - GEEETECH
For most people, the important thing to know about Resin 3D printing vs filament 3D printing, is concerning the materials used in the printing process. So let us dive deeper into when to use each type of printer and material. Enjoy!
What Is Resin 3D Printing?
Geeetech grey 3D resin
Geeetech resin
As the name suggests, this technology uses resin for printing 3D models. The resin starts as a liquid and is cured layer by layer during printing using UV or near-UV light. After printing, the model is usually washed and then post-cured under UV light.
Advantages and Disadvantages
Resin 3d printing makes it possible to achieve very good results when it comes to precision and specific details. This is because resin printers can produce very fine layers and cure each layer with high positional accuracy, resulting in excellent detail and smooth surfaces.
However, the technology is not as quick compared to other methods such as plastic or polymer filaments. And the cost for the resin also tends to be higher per weight unit. Some types of resin are also toxic or dangerous to handle without proper care.
What Is Filament 3D Printing?
Geeetech Thunder 3d printer
This is the type of 3D printer material that most people are familiar with. It uses some form of filament, which can be made from a wide variety of different ingredients. Different filament types offer different properties. PLA is easy to print, PETG provides good toughness and water resistance, ABS offers better heat resistance, and TPU is flexible.
On the positive side, the technology is well developed now, with high production efficiency resulting in effective cost control, so you can find cheap 3D printing filament.
That being said, there are also some possible things to consider, such as the slightly worse precision and details for FDM printing. The surface can sometimes require people to sand or smooth it for a more polished finish.
Comparison of Resin and Filament 3D Printing
Black Myth Wukong Monkey printed by Geeetech washable resin and Christmas tree printed by Geeetech PLA filament
Left: Black Myth Wukong Monkey printed by Geeetech washable resin ( Model source: Qicamo @MakeWorld )
Right: Christmas tree printed by Geeetech PLA filament ( Model source: Genapart @thingiverse )
Below you can see an overview of both Resin 3D printing and FDM printing. We have compared both methods on a number of different aspects.
Aspect Resin 3D Printing Filament 3D Printing (FDM)
Cost Higher Lower
Detail High Moderate
Surface Finish Smooth Visible layers
Materials Limited Wide variety
Ease of Use Complex Beginner-friendly
Post-Processing Required (washing/curing) Minimal (sanding optional)
Build Volume Smaller Larger
Durability Brittle Stronger
Cleanup Messy Clean
Print Speed Moderate Faster
Environmental Impact Higher (chemical waste) Lower (e.g., biodegradable PLA)
Applications Detailed models, miniatures Prototypes, functional parts
Print Operation
Step/Setting Resin 3D Printing Filament 3D Printing (FDM)
Material Preparation Liquid resin poured into a vat Filament loaded into extruder
Printing Temperature No heating required Nozzle: 180-260°C, Bed: 50-110°C
Cooling/Fan Not needed Cooling fan for proper filament cooling
Print Speed Slow (~20-50 mm/s) Faster (~40-100 mm/s)
Layer Thickness Thin (0.01-0.1 mm) Thicker (0.1-0.3 mm)
Post-Processing Requires washing & UV curing Minimal (remove supports, sanding)
Printer Maintenance Clean resin vat & replace FEP Clean nozzle, replace filament spool
Safety Measures Handle resin with gloves and mask; proper venting Few precautions, mostly non-toxic PLA
Overall Filament 3D printing is easier for people to use. It does not require a complicated process with the resin vat, UV curing and chemical cleaning.
FDM printers are also easier to maintain over time, and they are less messy since plastic filament is easy to handle compared to liquid resin.
Print Speed
One of the main advantages of FDM printers is their greater speed. In general, 3D printing can be quite slow, especially for larger objects. So, print speed varies greatly between resin and FDM printing. MSLA resin printers can cure an entire layer at once, making them efficient for printing multiple small parts, while high-speed FDM printers can be faster for larger functional models.
Print Quality
Feature Resin 3D Printing Filament 3D Printing (FDM)
Surface Finish Smooth and polished Layer lines can be visible depending on settings
Detail Extremely high precision, ideal for intricate designs Moderate precision, good for functional parts
Gloss Naturally glossy (varies by resin type) Matte or semi-gloss finish
Touch/Texture Smooth, often requiring minimal post-processing Slightly rough without finishing steps
Color Options Wide variety of resins, often solid or transparent Extensive range of filaments, including color blends
Durability Brittle, especially for thin parts Stronger and more flexible materials (Depends on filament type)
Weight Lighter due to hollow printing options Heavier with solid prints
Mechanical Strength Limited, suitable for aesthetic or detailed parts Durable and functional for mechanical uses
Flexibility Specialized resins for flexibility Flexible filaments like TPU are available
Post-Processing Smooth surface after curing; additional polishing optional May need sanding, smoothing, or painting
Maintenance of Resin vs Filament 3D Printer
Aspect Resin 3D Printer Filament 3D Printer (FDM)
Cleaning After Use Clean the resin vat and build plate with isopropyl alcohol Remove the filament, clean the nozzle and bed
Material Handling Keep resin sealed, avoid spills Store filament in a dry, airtight container
Bed Maintenance Keep the platform clean Level the bed and clean it regularly
Mechanical Parts Periodic replacement Lubricate linear rails and check belts
Consumables Replace FEP film regularly Replace worn nozzles
Safety Measures Gloves and proper ventilation Avoid touching the hot nozzle/bed
Storage Avoid exposing resin to sunlight Avoid moisture for filament
Error Prevention Check for cured resin residue Prevent clogging by cleaning nozzles
Printer Calibration Check Z-axis leveling Bed calibration and extrusion flow
Maintenance Frequency Often Rarely
FDM printers are often simpler to maintain on a daily basis, although nozzles, belts, fans, and other components may still require cleaning, adjustment, or replacement over time.
Applications
1. Miniatures and Figurines 1. Custom Cosplay Props
2. Custom Jewelry 2. Functional Tools
3. Display Models 3. DIY Home Decor
4. Detailed Decorative Pieces for Sale 4. Custom Toys and Gadgets
5. Educational Models 5. Replacement Parts
Conclusion
To conclude, 3D printing liquid resin models can deliver more precision and detail, at the cost of a more expensive model, slower production and overall more care and maintenance involved. It is still a viable option if you need the best quality possible or want to sell your items for the highest price possible.
Filament 3D printing is the best option when it comes to prototyping your own 3D printed designs and models, giving you quick and cheap results compared to Resin printing. The 3D printing machine types on the market are also cheaper and have fewer replacement parts needed.
Leave a comment
