Geeetech Thunder S 3D printer
Revision as of 02:17, 9 November 2023 by Admin (talk | contribs) (How to use Smarttokits)
Jump to: navigation, search
How to upgarde firmware
Smatto Kits
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
