Filament
Revision as of 06:16, 6 May 2023 by Admin (talk | contribs) (TPU)
Jump to: navigation, search
PLA
As for Geeetech PLA, the perfect settings in Cura slicer is shown as below: Nozzle temperature: 180-220 °C Bed temperature: 60-70 °C Print speed: 60-100 mm/s Initial layer height: 0.3 mm Initial layer print speed: 20 mm/s Travel Speed: At least 120 mm/s Retraction distance: 6 mm for Bowden setups, 2-3 mm for direct drive setups Retraction speed: 45 mm/s Cooling fan speed:100% Initial layer cooling speed: 0% Build plate adhesion: Skirt or Brim
PETG
As for Geeetech PETG, the perfect settings in Cura slicer is shown as below: Nozzle temperature: 220-230 °C Bed temperature: 70-80 °C Print speed: 40-50 mm/s Initial layer height: 0.3 mm Initial layer print speed: 20 mm/s Travel Speed: At least 120 mm/s Retraction distance: 6 mm for Bowden setups, 2-3 mm for direct drive setups Retraction speed: 25 mm/s Cooling fan speed:30-40% Initial layer cooling speed: 0% Build plate adhesion: Brim
ABS
As for Geeetech ABS, the perfect settings in Cura slicer is shown as below: Nozzle temperature: 230-250 °C Bed temperature: 80-100 °C Print speed: 40-50 mm/s Initial layer height: 0.3 mm Initial layer print speed: 20 mm/s Travel Speed: At least 120 mm/s Retraction distance: 6 mm for Bowden setups, 2-3 mm for direct drive setups Retraction speed: 25 mm/s Cooling fan speed:0% Initial layer cooling speed: 0% Build plate adhesion: Brim
TPU
Nozzle temperature: 200-210°C
Bed temperature: 60 °C
Print speed: 30-40 mm/s
