Geeetech Thunder 3D printer
Revision as of 08:49, 3 May 2023 by Admin (talk | contribs) (How to replace a nozzle)
Jump to: navigation, search
Product Features
•Technology: FDM
•Dual Z-axis
•Break-resuming capability
Parameters
Notice
Cura Configuration File
User Mode Introduction
Smatto Kits
•First Layer Mode
•Curve Mode
•Corner Line Threshold
•Max Junction
•X/Y Frequency
•Acceleration
•Jerk
•Extruder
General Page
Motor Page
PID Page
Custom Page
Firmware Upgrading
UI Upgrading
Usage Suggestions
How to clean the hotend
2. Remove the heat block kit.
How to replace a hotend
1. Disassemble the hotend kit
2. Install the new hotend kit
Nozzle discharge abnormality
First layer abnormal
Layer shift
Filament
Part Cooling Fan:
M106 P0 S128 ; ON MainFan 50%
M106 P1 S128 ; ON Aux Fan 50%
M106 P1 S0 ; OFF Aux Fan
How to Acquire Support
Steps:
How to Buy
Click to Purchase
