Geeetech Thunder 3D printer
Revision as of 07:29, 12 August 2022 by Admin (talk | contribs) (Product Specifications)
Jump to: navigation, search
THUNDER is a high speed FDM 3D printer with a printing speed of up to 300mm/s. After two years of research and development and testing by GEEETECH engineers, it has achieved high speed printing while ensuring excellent printing quality. It is an excellent 3D printer that can save a lot of precious time for 3D printing enthusiasts.
Product Features
•Technology:FDM
•High speed printing,speed up to 300mm/s
•Motor control:X/Y axis adopts closed-loop drive control,Z axis adopts TMC2208 drive
•Dual Z-axis
•Strong cooling hotend fan:4010*1, Part Cooling Fan:5015*2, Auxiliary Part Cooling Fan:6020*2
•Leveling:support manual leveling and auto-leveing
•Filament broken detection:standard packed with filament broken detection sensor
•Screen password protection:During the printing process, the screen is locked with a password to prevent the printing failure caused by the accidental change of printing parameters
•Multi printing modes:THUNDER inserted 4 printing modes for different speed level printing, meanwhile, it has a User Mode for users to customize printing parameters
•Break-resuming capability
•Printing lighting: THUNDER designed a white LED light on the hotend, convenient for checking the nozzle and model condition
•CPU: ARM Cortex-M4 Core,168MHz
•Printing Speed: ≤300mm/s
•Maximum Acceleration: x=5000mm/s²,y=4000mm/s²
•Motion Controller CPU: ARM Cortex-M3 Core,72MHz
•Nozzle Max Temperature: 250℃
•Hotbed Max Temperature: 110℃
•Nozzle Diameter(Optional): 0.2mm,0.6mm,0.8mm
•Filament Diameter: 1.75mm
•Power Input: AC 115/230V,50/60Hz
•Power Supply: 350W
•Net Weight: 10.7kg
•Packing Weight: 13.4kg
