GT2560
Revision as of 07:40, 1 July 2015 by Admin (talk | contribs) (Interface Layout)
Jump to: navigation, search
GT2560 is a compact board that is integrated with the mighty function of the Arduino Mega2560+Ultimaker and Arduino Mega2560+ramps 1.4 on respect of both software and hardware and has more premium features: the streamlined interfaces effectively avoid the unnecessary troubles, well-regulated compaction of components highly integrated saves more space and easier to be mounted on most applications.
5 stepper motors, swappable driving modules, mighty ATmega2560 processor with 256k memory, 16MHz operating frequency, high-performance USB serial converter FT232RQ, all these make the GT2560 an ideal option for a 3D printer control board. What’s more, GT2560 can run over 12V to 24V which gives higher torque and higher rotation rate.
                         (front and back images)
Hardware resources:
3 input for12V cooling fan
1 PWM output
Weight: 80 g
Software Resources
Firmware: Marlin
Host software:printrun Repetier-Host
Source
Arduino ide
Marlin
printrun
Repetier-Host
Interface specifications
1.DC IN: 12V 12A and 12V 5A
2.HOT_BED: heat bed
5.LCD ENCODER: LCD panel
6.SD Card
The subdivision of stepper motor can be setup by dial switch, turn on all the dial switch, as the arrow shows
2-2.jpg 2-2
Turn ON/OFF            Subdivision
MS1    MS2    MS3
OFF    OFF    OFF    full step
ON     OFF    OFF    1/2 step
OFF    ON     OFF    1/4 step
ON     ON     OFF    1/ 8 step
ON     ON     ON     1/16 step
MS1    MS2    MS3
ON     OFF    OFF    1/2 step
OFF    ON     OFF    1/4 step
ON     ON     OFF    1/ 8 step
OFF    OFF    ON     1/16 step
ON     OFF    ON     1/32 step
OFF    ON     ON     1/32 step
ON     ON     ON     1/32 step
Software setting
Then, windows will open the dialog box “found new hardware wizard”, check “no, not this time”, then click “next” to continue. 3-5.jpg
Then, windows will open the dialog box “found new hardware wizard”, Check “install from a list or specific location (advanced)”, then click “next”. 3-6.jpg
Specify installation directory where FT232RQ is to install driver. Click “browse” to find the directory and click “next” to continue. 3-7.jpg
Click "Continue" in Read me.
Click "Continue" in License.
File Burning
firmware, as shown below.
Get Started
#define BAUDRATE 250000
#define MOTHERBOARD 7
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_BED 1
 #define EXTRUDE_MINTEMP 170
#define INVERT_X_DIR false
#define INVERT_Y_DIR true
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_POS 205
#define X_MIN_POS 0
#define Y_MAX_POS 205
#define Y_MIN_POS 0
#define Z_MAX_POS 200
#define Z_MIN_POS 0
At most 2 extruders, GT2560 supports 5 A4988 stepper motor drivers, they are X/Y/Z axis and 3 extruders.
2. What is the Power Requirement of GT2560?
It is 12V 12A for the heatbed and 12V 5A for the logical part.
How to get
Visit here now!
