Metal J-head short-distance
Jump to: navigation, search
This product adopts high-quality aluminum alloy heat radiator and brass nozzle, with stainless steel pipe as feeding pipe, which ensures good heat insulation effect and prevents blockage. Besides, its surface is covered with anodic oxide coating, which can resist oxidation corrosion and increase nozzle hardness, thus ensuring better heat insulation, stronger corrosion resistance as well as finer and more stable printing.
Feature
Configurable cooling fan, cooling effect.Assembled short-distance J-head with fan for bowden extruder
Product Introduction
Printing resolution 0.1mm
Molding form FDM
Material Metal
Nozzle temperature 180℃-240℃
Outline dimensions 70*25*25mm L/H/W
Weight 68g
Input voltage default to 12V
Cartridge heater 12V 30W
Click here to buy Metal J-head short-distance
http://www.geeetech.com/all-metal-shortdistance-jhead-for-bowden-extruder-p-790.html
