Display problems of LCD2004/12864
Dio Serpente
Re: Display problems of LCD2004/12864
Post by Dio Serpente » Mon Aug 27, 2018 3:31 pm
Good morning, I have a problem with the printer.
As soon as I finished editing I turned on the printer that seemed to work properly, the display appeared on the insert SD Card, after a couple of minutes the screen became completely black and no longer worked.
The printer was mounted correctly and I checked the connections several times.
It's really frustrating, mount the printer in several hours and find this flaw.
... :arrow: :arrow:
Post by _kaktus_ » Mon Aug 27, 2018 6:16 pm
:mrgreen:
What model of printer you have - reveal this secret :!:
Post by William » Tue Aug 28, 2018 10:09 am
Will it show anything?
Or it just seems dead.
If you can attach a pic of it,we can give you more helps. :D
dga78
Post by dga78 » Fri May 03, 2019 11:50 am
William, Im having the same LCD issue.
I have flashed the firmware with the above config and still getting the rectangles on the screen.
i3 pro x with 2004.
please help
Post by William » Sun May 05, 2019 9:39 am
Hi, You can use a multimer to measure the voltage on the main board.it should be 5V.
andrezanna
Post by andrezanna » Sun Jul 07, 2019 6:16 pm
Hi, i have another problem with the lcd.
Sometimes it gets mad and start doing like in photo.
https://drive.google.com/file/d/1Zi1hQ ... p=drivesdk
By he way, it continues printing normally.
What could this be? Should I worry?
Post by William » Mon Jul 08, 2019 9:14 am
Hi, You can try to reconnect the cable of the LCD screen. This can happen due to poor contact.
