Problems whit the Software
Levin
Post by Levin » Tue Aug 14, 2018 3:13 pm
I have got the Prusa I3 Pro W and the Objekts are not the best ones. I think the sofware is the Problem. I will upload a new Software whit Arduino IDE
but there is an eror massage:
Code: Select all
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
                 from C:\Users\levin\Downloads\Marlin\Marlin.ino:33:
 #define X_MAX_PIN          -1
 #define X_MAX_PIN 24
 #define Y_MAX_PIN          -1
 #define Y_MAX_PIN 28
 #define Z_MAX_PIN          -1
 #define Z_MAX_PIN 32
                 from sketch\cardreader.h:8,
 struct fpos_t {
exit status 1
I hobe you can understand me.I m from Germany.
here are a failed Objekt
https://drive.google.com/open?id=1dvZvQ ... OnK8MVCu5S
Gingko
Re: Problems whit the Software
Post by Gingko » Wed Aug 15, 2018 6:16 pm
This compile error it's because the firmware in the forum is an old version, if you use Arduino 1.0.1, you can compile successfully.
As for the printing quality, please first confirm that if the heatbed is properly leveled.
How much is the Z step/mm?
BR365
Post by BR365 » Thu May 09, 2019 4:56 pm
I don't think that it is a firmware problem. The board and firmware is the same as it is for the i3 Pro B and I use the GT2650 board with i3 Pro W firmware with my i3 Aluminium:
The idler replacement part was printed with the i3 Aluminium with 1i Pro B/W board and firmware.
BR365
Post by BR365 » Thu May 09, 2019 5:03 pm
vert wrote:
Thu May 09, 2019 4:59 pm
Would still suggest thinking about upgrading to Marlin 2.
Is there a Marlin 2 based official firmware available for i3 Pro B / C / W and A10 / A20 family printer?
