Geeetech A10 firmware Marlin 1.1.9
Moderator: vert
zonalimitatore
Re: Geeetech A10 firmware Marlin 1.1.9
Post by zonalimitatore » Tue Aug 28, 2018 10:44 pm
Perfect.Tonight i try to flash ;)
MichaelK
Post by MichaelK » Wed Aug 29, 2018 12:51 am
Into the menu you found the new setting "manual leveling"
To use them klick the wheel down and start the leveling. The A10 now drives 9 points on the heating bed, starting with point 1.
Put a piece of paper under the nozzle and turn the wheel up and down until the distance fits.
Push the wheel down and the A10 move to position 2.This is done with all 9 points from the heatbed.
After point 9 you here a "Sound" thats say "configuration saved into the EEPROM"
Into the leveling menu you could set "Leveling correction" to "Yes"
The printer use your own points from the heatbed to correct the z-axis now!
You didn't redo level of every print. If prints are bad you could level again.
Bevor leveling the heatbed look under your nozzle, because to level the heatbed there must not be any filament under the nozzle!!!
Try it. :mrgreen: The results with manual 9 point leveling and 0.1 layer high are very, very good!!!
zonalimitatore
Post by zonalimitatore » Wed Aug 29, 2018 2:01 am
perfect perfect perfect :mrgreen:
zonalimitatore
Post by zonalimitatore » Wed Aug 29, 2018 7:55 am
Omg....it's in doich lenguage!!!!!!! :shock:
How change?
zonalimitatore
Post by zonalimitatore » Wed Aug 29, 2018 9:22 am
I dont know what happen,but i cant upload a firmware on my print
After i send the last message,i try to upload Marlin.ino.with_bootloader.mega.hex using xloader
Wel....i wait about 15min and after that program still "uploading".
I disconnect the usb,and now i have a print with light on display,but no characters
So,i try to repload the Marlin.ino.mega.hex but nothing.....yellow leds doesnt turn on/flashing
I only have ON 12VE 12VB leds on
Every time a led called D2 flash for a very little time
What it's going on? Im disperate :( :( :( :(
MichaelK
Post by MichaelK » Wed Aug 29, 2018 2:21 pm
You flash the firmware onto your own risk! I mention that everywhere!
Disconnecting every machine during flashing can damage the bootloader!
First, don't install the version with bootloader included. The bootloader already installed.
Look here to load and use the original firmware: viewtopic.php?f=20&t=17046
It's possible you need to flash the bootloader again. It's tricky, search into the forum to "bootloader"
Later the day, i change the firmware on thingiverse. It's my mistake. In the configuration.h you could find the "LCD-Settings" and here you can change the language from de to en or other language.
zonalimitatore
Post by zonalimitatore » Wed Aug 29, 2018 4:34 pm
I need to use Arduino uno for write it?
zonalimitatore
Post by zonalimitatore » Wed Aug 29, 2018 5:13 pm
I cannot find where to connect the comunication wires on the board fot comunicate with arduino uno
MichaelK
Post by MichaelK » Wed Aug 29, 2018 5:50 pm
I do not know if my connections that I know really fit, but you can write to the support to tell you the connections:
https://www.geeetech.com/technical_support.html
zonalimitatore
Post by zonalimitatore » Wed Aug 29, 2018 6:32 pm
Anyway...i need to rewrite the bootloader using my arduino uno like programmer,right?
Users browsing this forum: No registered users and 11 guests
