I installed a BL Touch and was trying to set the offset on the z axis s by using the M211 S0 command to disable the soft end stop.
For some reason this command does not work the board is a gt2560 on a geeetech I3 Pro B W.
Any help would be appreciated.
Robert
M211 S0 Not working.
Re: M211 S0 Not working.
Seems that marlin doesn't support "M211" code.
I guess you can set z offset directly by M851.
- 1.png (12.2 KiB) Viewed 9070 times
- 3.jpg (103.31 KiB) Viewed 9070 times
Was using Repetier which I found out does not support turning off the soft endstop.
I tried Easyprint 3D and worked no problems.
Thanks for the help.
