How to fix-E180>The screen displayed not correct or black screen
Admin
Post by Admin » Tue Jan 23, 2018 5:33 pm
Hi, guys!
How to fix the screen displayed not correct or black screen-E180?
Well.Here are the files for the LCD:
e180-lcd.rar
(613.54 KiB) Downloaded 1913 times
Updates:New UI for E180
E180_UI for v1.32.41.zip
(440.24 KiB) Downloaded 1935 times
Guide
1.You should open the side protection cover
2.You should take off the sd card
3.Format the SD card
4.Copy the un-zip files to root directory of the sd card
jhoff
Re: How to fix-E180>The screen displayed not correct or black screen
Post by jhoff » Sun Jan 28, 2018 9:40 am
I downloaded the file but cannot unzip it because it requires a password. Please advise. Thank you!
Post by William » Tue Jan 30, 2018 9:58 am
I have downloaded, and did not find the need for a password
Post by _kaktus_ » Wed Jan 31, 2018 3:31 am
I wonder why you do not give checksums to files that can be downloaded on the forum.
vital
Post by vital » Mon Mar 12, 2018 2:05 am
Do you have step by step instruction how to open side cover without damage printer?
I need to remove some screws.
michaelconti
Post by michaelconti » Sun Mar 25, 2018 10:40 am
I donwload the file, formatted the SD, copy the file and...result is a wrong screen...not working only white and black line :(
michaelconti
Post by michaelconti » Sun Mar 25, 2018 6:45 pm
I have a problem, i have do everything in the right sequence but after that my disply don't work anymore and the sd too...
Post by William » Tue Mar 27, 2018 9:24 am
Could you upload a screenshot of the sd card root directory?
michaelconti
Post by michaelconti » Thu Mar 29, 2018 2:17 am
i found was the sd don't working anymore, so i changed it but bow when i print from sd, object with large dimension the printer reset and stop print
Post by William » Thu Mar 29, 2018 6:44 pm
Could you upload the Gcode of your sd card?
