VS1053 shield record example
nava
Post by nava » Thu Sep 08, 2016 12:33 am
Hi all,
I am looking fro an example arduino code to try recording using the on board mic on the geeetech shield. Would be great to get a basic example.
I have tried the example that adafruit has but cant get it up and running..probably a pin miss match
for your reference here is the example by adafruit
https://learn.adafruit.com/adafruit-vs1 ... g-recorder
and the basics of the pin connections to the arduino are as follows
Code: Select all
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// define the pins used
#define RESET 8      // VS1053 reset pin (output)
#define CS 9        // VS1053 chip select pin (output)
#define DCS 6        // VS1053 Data/command select pin (output
#define CARDCS A1     // Card chip select pin change from digital pin 4
#define DREQ A0       // VS1053 Data request, ideally an Interrupt pin// changed from digital pin 3
#define REC_BUTTON 7
IfNotNow
Re: VS1053 shield record example
Post by IfNotNow » Fri Feb 23, 2018 1:24 pm
Were you able to figure out how to get the mic on the geeetech shield to record? I'm having exactly the same issue you described below. Any help will be greatly appreciated.
Thanks!
