BLtouch on 24V GT2560
reddo
Post by reddo » Mon Feb 05, 2018 2:46 am
I'm running a GT2560 on 24V with the jumper in place and am in the process of adding a BLtouch sensor (on the Zmin and max pins as per the Geeetech instructions for the older GT2560)
Now I'm wondering, will I kill the BLtouch as I'm running 24 Volts ??
Re: BLtouch on 24V GT2560
Post by William » Mon Feb 05, 2018 5:24 pm
Don't worry!It can works at 24V psu
reddo
Post by reddo » Tue Feb 06, 2018 12:57 am
Thanks, working indeed.
Only had to add the SERVO0_PIN 32 in pins_gt2560_A to make it work, this one is normally assigned to the endswitch and is not assigned to the BLTouch (it is corrected in the A+ pins but since I use the older A revision where I soldered a 3-pin header to the z-endswitch.....)
reddo
Post by reddo » Tue Feb 06, 2018 6:41 am
It worked for 2 hours or so.. then the BLtouch lost the red led... After checking, the +5V pin on the GT2560 (the one extended from the z-axis endswitch as per the Geeetech recommendations) has no more 5V... the ones next to it do strange enough.. Any hints on this ? Crack in the PCB ?? Solder a wire now to the neigbouring +5V and hope it will stay alive....
Users browsing this forum: No registered users and 7 guests
