Basic guide to lead screw upgrade, i3 Pro B
Will2018
Post by Will2018 » Mon Jan 08, 2018 6:23 am
Is there a basic guide to upgrade the i3 Pro B threaded screws to lead screw please?
Ie how to make the hardware change and also the software plus any extra calibration.
Also advice on which lead screws to purchase. This is for the Z axis.
Re: Basic guide to lead screw upgrade, i3 Pro B
Post by William » Mon Jan 08, 2018 7:46 pm
You can refer to this
Will2018
Post by Will2018 » Thu Jan 11, 2018 4:54 am
Ok, thanks. But..
1) that setting doesn’t seem to get remembered by the printer.
And 2) the head doesn’t return to correct Z origin and judders when trying to move.
Is it because the motors aren’t suitable for a steps value of as little as 400? Should I swap back to threaded rod?
Post by William » Thu Jan 11, 2018 10:25 am
You should upload the Configuration.h to google drive and share the link with me, I can give you some suggestions
Alienmoon
Post by Alienmoon » Sat May 12, 2018 4:59 am
@William
I've just added the T8's to my first printer and I've been looking for anything related to editing the firmware for the T8s.
I take it with you adding the above reference, that you've also done this mod?
If so, me being new n all, so I just copy what you've entered and I should be good to go?
@Will2018
Did you ever get this fixed?
If so, could you please, share any working edits to the firmware in relation to the T8s?
Thank you to both of you, any pointers would be appreciated.
