New 2017 firmware for rostock 301 ?
Re: New 2017 firmware for rostock 301 ?
You can download the firmware I attached and you can up to the temp to above 220 degrees and the max temp is 270.
After upgrading to 1.0.3 my printer does not recognize any negative coordinate values. so now it can only travel in the positive areas away from the origin. When I tried to go back to 1.0.2 it bricked my board and I was only able to use EasyPrint to get it back to 1.0.3 whihch obviously doesn't work. I hate this printer....
Obviously, the uploading is not successful completely. The only way is re-upload the firmware again. You can use the EasyPirnt 3d or Flash loader demo to upload.
Hello.
It returns to the original, but it does not become 270 ℃.
Learn more How can I install firmware at 270 ℃?
I tried the following.
1. Bootloader V 1.0.1 installation ⇒ NG
2. gtm32 machine delta.bin installation ⇒ NG
3. rostock 301 v1.0.3.bin Installation ⇒OK (Max 220 ° C)
- IMG_6215.JPG (143.97 KiB) Viewed 6651 times
