How to install the firmware for GT2560
Locked
Hammer08
Re: How to install the firmware for GT2560
Post by Hammer08 » Thu Dec 15, 2016 11:08 am
completely new to the program aspect of using a 3d printer but got to the point where i used marlin for my gt2560+a4988 board and when i go to verify it i keep getting the following error and i dont understand it any help would be much appriciated.
from C:\Users\Wraith\Desktop\Marlin-PI3_Pro_B\Marlin\Marlin.ino:33:
#define X_MAX_PIN -1
#define X_MAX_PIN 24
#define Y_MAX_PIN -1
#define Y_MAX_PIN 28
#define Z_MAX_PIN -1
#define Z_MAX_PIN 32
from sketch\cardreader.h:8,
struct fpos_t {
c:\program files\windowsapps\arduinollc.arduinoide_1.6.13.0_x64__mdqgnx93n4wtt\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
exit status 1
Cup
Post by Cup » Thu Dec 15, 2016 11:38 am
Hammer08 wrote:completely new to the program aspect of using a 3d printer but got to the point where i used marlin for my gt2560+a4988 board and when i go to verify it i keep getting the following error and i dont understand it any help would be much appriciated.
struct fpos_t {
exit status 1
Arduino 1.0.1 will fix it:
http://www.geeetech.com/wiki/images/a/a ... indows.zip
pekkap100
Post by pekkap100 » Tue Dec 27, 2016 4:52 pm
hey just acquired the printer (prusa pro c ) and tried to change the direction of the motor. something was wrong, lcd emptied. I tried to put a new program but not work. it come: exit status 1 error for combiling board.I have tried to new and old Arduino.
Cup
Post by Cup » Tue Dec 27, 2016 5:33 pm
@ pekkap100
Maybe you can attach the screenshot of the error msg.
pekkap100
Post by pekkap100 » Tue Dec 27, 2016 6:12 pm
now i open that file arduinoisp and it went through but nothing happened. lcd is still empty.
Cup
Post by Cup » Wed Dec 28, 2016 12:00 pm
First make sure you have the SD and LCD cable correctly connected.You can try swapping them.
You said you have some errors in Arduino,so could you attach some pictures or videos to show us the issue?
pekkap100
Post by pekkap100 » Wed Dec 28, 2016 8:17 pm
hei here a couple of videos:https://www.youtube.com/watch?v=nE9otEj ... eg&index=4
https://www.youtube.com/watch?v=kl1KXj3 ... 8GgtRAI8eg
the second video will error:no such file or directory an the other i open file arduinoisp and then load successfully,but the display remains blank
pekka
bang
Post by bang » Thu Dec 29, 2016 6:09 pm
pekkap100 wrote:hei here a couple of videos:https://www.youtube.com/watch?v=nE9otEj ... eg&index=4
pekka
Hi,Pekka
I noticed you just open one file to Arduino.
You need select all the files in the firmware folder and drag them to Arduino then upload...
pekkap100
Post by pekkap100 » Thu Dec 29, 2016 9:53 pm
ok but in this example: http://www.geeetech.com/forum/viewtopic ... 20&t=17181only one ino file open? Pekka
Cup
Post by Cup » Fri Dec 30, 2016 9:50 am
pekkap100 wrote:Hi
But have you noticed this?
It contains all the files of the firmware,while you have only one in your Arduino.
Did you get my idea?
Locked
