Rostock 301, new firmware changelog
raoulito9
Post by raoulito9 » Tue Oct 11, 2016 6:00 am
There is a new firmware for rostock 301.
ROSTOCK301_V1.0.0.2.zip
(63.6 KiB) Downloaded 29 times
Can you give us the changelog ?
Is it worth burning ?
Re: Rostock 301, new firmware changelog
Post by William » Tue Oct 11, 2016 4:37 pm
It repaired some bugs,including the stoping in half of the printing process and failing to read SD card.
flintewn
Post by flintewn » Tue Oct 18, 2016 10:22 pm
As i mentionned in another post, release the source code, you are using marlin who is under GNU GPL v3.
JohnQuix
Post by JohnQuix » Sat Nov 26, 2016 10:48 am
Is there a reason this printer doesn't just run a regular open version of Marlin like the rest of your printers?
This type of hot end has been supported in Marlin for awhile now so it can't be that anymore.
If you guys make it a regular Marlin that we can self service it will save Geeetech a lot of support issues.
Lami René
Post by Lami René » Fri Dec 09, 2016 9:46 pm
Bonjour,
You will find the original text translated into English following this original French text.
Pourriez-vous demander à vos plus hauts responsables de libérer le code source de la carte contrôleur GTM32 Pro de l'imprimante 3D delta Geeetech 301 (M301) ?
C'est une demande officielle pour vos plus hauts responsables !
Merci d'avance pour toutes les démarches que vous ferez pour cela !
Cordialement,
L'ami René
Could you ask your top managers to release the source code of the controller card GTM32 Pro 3D printer delta Geeetech 301 (M301)?
This is an official request for your top managers !
Thank you in advance for all the steps you will make for this!
Cordially,
Friend René
Lami René
One for all and all for one !
JohnQuix
Post by JohnQuix » Fri Dec 09, 2016 9:50 pm
It is definitely Marlin which means the source code is required to be openly available.
We would still need a way to turn the code into a file that would be flashable for an stm32 based system.
Lami René
Post by Lami René » Fri Dec 09, 2016 10:05 pm
Hello JohnQuix,
Bonjour JohnQuix,
Oui, c'est l'IDE Arduino qui est disponible pour les systèmes d'exploitation Linux, Mac OS et MS-Windows.
Voir : https://www.arduino.cc/en/Main/Software
Cordialement,
L'ami René
Hello JohnQuix,
Yes, the Arduino IDE is available for Linux, Mac OS and MS-Windows operating systems.
See: https://www.arduino.cc/en/Main/Software
Cordially,
Friend René
JohnQuix
Post by JohnQuix » Fri Dec 09, 2016 10:17 pm
I don't think that the GTM32 speaks to Arduino IDE
flintewn
Post by flintewn » Fri Dec 09, 2016 10:24 pm
That's the point raised by rené.
theyhave used marlin to create the firmware, why the stm32 did not use arduino ide ?
JohnQuix
Post by JohnQuix » Fri Dec 09, 2016 11:01 pm
I think if we were able to edit the firmware ourselves it would probably save Geeetech a lot of tech support problems.
Users browsing this forum: vert and 8 guests
