3D Touch Sensor:Auto-levelling for Geeetech 3D printer
JohnQuix
Re: 3D Touch Sensor:Auto-levelling for Geeetech 3D printer
Post by JohnQuix » Tue Oct 25, 2016 8:54 pm
@William
Are there any instructions on how to hook the 3DTouch up to a MeCreator 2?
UndCon
Post by UndCon » Tue Oct 25, 2016 10:21 pm
HI!
I installed my Sensor and modified the firmware (I hope correctly, the instructions are not very easy to understand)
Anyway...
When I power up I get the selftest 3 time movement.
When I try to send any command from Repetierhost in the G-code window it says nothing and do nothing.
Not even the alarm test works.
When I try to move Home in all axis Z says "Z probe out. bed"
In this case it doesnt matter if probe is lit or not, in or out...
JohnQuix
Post by JohnQuix » Wed Oct 26, 2016 12:36 am
@JumpBase
Thanks so much for uploading that bracket. Unfortunately I use that side for my fan. The two screw holes on the carriage fit a turbo fan perfect so I can't move the fan. :(
Back to the drawing board.
@William
Is there a guide or instructions that I can read to get the 3DTouch wired to my Me Creator 2?
elfag.blogg.no
Post by elfag.blogg.no » Wed Oct 26, 2016 7:35 pm
It worked for one day, now it wont work at all
UndCon
Post by UndCon » Thu Oct 27, 2016 1:08 am
Can someone Please post their config.h and pins.h files so I can verify correct settings?
UndCon
Post by UndCon » Thu Nov 03, 2016 4:23 am
I found an error I made...
According to the instructions here:
http://www.geeetech.com/blog/tag/3dtouc ... ng-sensor/
I connected the 3pin BROWN - RED - ORANGE to the GT2560 board _ Not BROWN, ORANGE, RED as it is supposed to be...
I simply assumed the 3pin was a straight connector (I used a regular RC extension)
Question: Did I ruin this port on the board when ORANGE and RED got mixed up?
Question: Can I save it by using another free 3pin connector by assigning another PIN?
Question: Did I ruin the sensor ?
BR
UndCon
UndCon
Post by UndCon » Thu Nov 03, 2016 10:21 pm
Thx for the provided files configurationh and pins.h
This did not help me at all, I have the correct settings on my printer - but sensor does still not work.
Post by William » Fri Nov 04, 2016 11:34 am
UndCon wrote:Thx for the provided files configurationh and pins.h
Maybe the wire order is a problem,could take a picture of your wire order?
UndCon
Post by UndCon » Fri Nov 04, 2016 5:31 pm
Like I wrote above I found a mistake with wires and corrected it.
/UndCon
Dppp
Post by Dppp » Wed Nov 09, 2016 3:33 am
I purchased 3D touch sensor to my Prusa I3 Pro B and today I installed it to printer, but I was not able to get it working. When I power up printer, pin is mowing 3 times, but when I try to send any custom G-codes, nothing happens. What should I do / check next to get it working? All needed firmware modifications are done.
UndCon: Did u managed to get your sensor to working?
Locked
