3D Touch Sensor:Auto-levelling for Geeetech 3D printer
Locked
Post by William » Wed Sep 21, 2016 3:53 pm
Hi, there
Tired of leveling your heat bed manually?
Would you like to add an auto-leveling system for your printer?
For me, the answer must be "YES".
Now,here comes our protagonist:3D Touch Sensor
Her chief features are:
Simple,Smart,High-precision,Innovative Solenoid: Ultra Power Saving,Technologies,wide Selection of Bed,Optimized structure: Larger Build Size
I've already add it on my printer,it is so charming and has a perfect performance on it.Here is a video about it:
https://www.youtube.com/watch?v=7aav0i5cOL4
More importantly,everyone(a newbie or experienced guy) has a easy access to the Auto-levelling world,cuz there are detailed guides(including software and hardware) in the manual.
I3 ProB-3DTouch auto leveling sensor User Manual.zip
(1011.05 KiB) Downloaded 5337 times
I3 X-3DTouch auto leveling sensor User Manual.zip
(1.35 MiB) Downloaded 3392 times
I modified the firmware for they two,you guys can have a reference:
Old GT2560 A board:
Marlin-PI3_Pro_B_3DTouch.zip
(314.85 KiB) Downloaded 3761 times
New GT2560 A+ board
Marlin-PI3_Pro_B_3DTouch (A+).zip
(324.69 KiB) Downloaded 3130 times
I3_pro_X_3D Touch.zip
(311.4 KiB) Downloaded 2744 times
So far,we've updated the manuals on I3 ProB and I3 X(the sensor only supports GT2560 board so far),i'll post it here once there is an updating on other models.
Do you guys wanna have a try?
You can get the sensor from here:
http://www.geeetech.com/3dtouch-auto-le ... -1010.html
Lami René
Re: 3D Touch Sensor:Auto-levelling for Geeetech 3D printer
Post by Lami René » Wed Sep 28, 2016 6:25 pm
Bonjour,
J'ai commandé une Geeetech Rostock 301 Mix Couleur 3-in-1 et un capteur de mise à niveau automatique 3DTouch. J'espaire que d'ici à ce que je recoive ma commande vous aillez produit une mise à jour logiciel et un guide d'installation pour un 3DTouch sur une Geeetech Rostock 301 !
Merci d'avance pour vos efforts !
One for all and all for one !
elfag.blogg.no
Post by elfag.blogg.no » Tue Oct 18, 2016 12:47 pm
I am sorry to say, but i think my sensor i broken. It only flash red light, but it dont push pin up or down.
I updated my marlin firmware with the help of the instructions from this site http://www.geeetech.com/blog/tag/3dtouc ... ng-sensor/
i use manual codes ( M280 P0 S10 ; pushes the pin down )
But no reaction another than blinking red light?
What should i do?
Post by William » Thu Oct 20, 2016 10:33 am
See the following picture:
elfag.blogg.no
Post by elfag.blogg.no » Fri Oct 21, 2016 11:43 am
Before printing all axis is going to home and that is a problem for z axis because it has no limit switch and because the sensor is using that terminal.
It does not perform auto leveling, . This must be a software thing, but i followed the manual for GT2560.
What can i do?
Ps. Sorry my bad english, i am Norwegian
Last edited by elfag.blogg.no on Wed Oct 26, 2016 7:34 pm, edited 1 time in total.
Post by William » Fri Oct 21, 2016 6:08 pm
You can show me more details about the issue,or you can attach a video from Youtube.
PS.There is no need to use a Z limit switch with 3D-Touch(3D-Touch detects 5 points on the bed.).
JohnQuix
Post by JohnQuix » Sat Oct 22, 2016 10:43 am
Has anyone got the 3DTouch to work with the MeCreator 2 yet?
Jumpbase
Post by Jumpbase » Sat Oct 22, 2016 8:00 pm
Not really, its almost working but the Z Axis drives down and not up when i use G28/G29
baxbax
Post by baxbax » Sun Oct 23, 2016 9:12 pm
Hi to everybody,
yesterday, I mounted this sensor , on my I3 Pro B but, but all work bad.
I did the modifications on Firmware Marlin, in Configuration.h and pins.h, like in the instructions.
I saw the wiki , where is an explanation of calibration : http://www.geeetech.com/wiki/index.php/ ... ing_Sensor
After that , every time the printer start , does the controls and when it started to print, the nozzle is , at least, 1mm from the bed.
Thanks in advance
Bye
Marco
Post by William » Mon Oct 24, 2016 10:30 am
@Marco
So you mean the Sensor works fine during the calibration but the nozzle is not in the right position when printing?
If you do,decrease the value "-1.4" in the following codes:
Code: Select all
#define Z_PROBE_OFFSET_FROM_EXTRUDER -1.4
You can decrease it to "-1.9" first to see if it makes a difference.
Locked
