GT2560 burnt heatbed socket
Perry_S
Re: GT2560 burnt heatbed socket
Post by Perry_S » Thu Feb 25, 2016 9:36 am
Unfortunately this has happened to me as well after about 2 months of use. Same connector for the hotbed.
Can anyone tell me where to find a replacement? Maybe a part number I could cross reference or something. I'd prefer something a bit better quality if possible. Ideally I need both sides since the pcb-side has a little damage as well.
Thanks!
Sherry
Post by Sherry » Thu Feb 25, 2016 3:08 pm
hi,the green socket is not sold on line. can you find it locally? the specifcation is : 2pin 180°,RC508(R),5.08mm.
Perry_S
Post by Perry_S » Fri Feb 26, 2016 3:52 am
Yes, I can find these locally but all are only rated to 10 Amps. I can not find any connectors with the 5 mm pin spacing that are rated above 10 amps. I believe the original ones were only rated for 10 amps and used in this 15 amp circuit and the reason we are seeing thesse burning.
Mark
Post by Mark » Fri Feb 26, 2016 4:48 pm
how about check this one, it says 15A:
http://www.ebay.com/itm/10-Pcs-5-08mm-P ... 1201924630
Perry_S
Post by Perry_S » Sat Feb 27, 2016 5:49 am
Thanks,
Was hoping to find something local in the US but I will give them a try.
judarc
Post by judarc » Mon May 23, 2016 11:01 am
Hi, the same thing to me, but today the damaged was on the main DC power plug, I plan to solder the cables directly to the PCB and see if they don't get hot as soon as I turn the bed on.
After burning the green plug once, now this happened
2016-05-22 21.57.07.jpg (399.49 KiB) Viewed 4047 times
Users browsing this forum: No registered users and 5 guests
