Firmware for geeetech 3D printers
Mark
Re: firmware for geeeteh 3D printers
Post by Mark » Tue Dec 01, 2015 11:54 am
Does your Y motor work? or you can check the endstop wirings, is it correct?
maybe you can check this link here:
http://www.geeetech.com/forum/viewtopic ... 13&t=17038
Pakatakapons
Post by Pakatakapons » Thu Dec 10, 2015 11:23 am
I have PI3 Pro C. I download from post above firmware for my printer - Marlin_GT2560_PI3_Pro_c.zip. I have Arduino IDE last version and i not changed any files or options in configuration.h.
But in compilation process Arduino Ide send error message:
"temperature.cpp: In function ‘void manage_heater()’:
temperature.cpp:665:1: error: unable to find a register to spill in class ‘POINTER_REGS’
temperature.cpp:665:1: error: this is the insn:
(insn 95 94 97 4 (set (reg/v:SF 103 [ pid_input ])
(mem:SF (post_inc:HI (reg:HI 146 [ ivtmp.209 ])) [4 MEM[base: _110, offset: 0B]+0 S4 A8])) temperature.cpp:449 99 {*movsf}
(expr_list:REG_INC (reg:HI 146 [ ivtmp.209 ])
(nil)))
temperature.cpp:665: confused by earlier errors, bailing out"
Have you a working firmware for PI3 Pro C?
Mark
Post by Mark » Thu Dec 10, 2015 2:27 pm
The firmware is working. i think you can use another arduino to compile it, the latest version always have some wierd problems, and use win7 .
Pakatakapons
Post by Pakatakapons » Thu Dec 10, 2015 2:36 pm
It work with Arduino IDE 1.0.1. Arduino IDE 1.6.5 don't work. I don't knew why. All done, thank you.
Your firmware based on latest version marvel?
Mark
Post by Mark » Thu Dec 10, 2015 3:53 pm
I remember based on 1.0.2 or 1.0.3, you can check it in configuration.h tab.
jlbadvance
Post by jlbadvance » Sun Dec 20, 2015 6:00 pm
Hello!
I want tu put a second extruder on my geeetech i3 proB (GT2560). Can i use directly the firmware of I2 proC? Or do i need to modify the I2 proB firmware?
Mark
Post by Mark » Tue Dec 22, 2015 4:44 pm
just use the firmware for I3C, no need to modify it.
Oh, maybe you can change the limits according to your bed here:
// Travel limits after homing
#define X_MAX_POS 210
#define X_MIN_POS 0
#define Y_MAX_POS 210
#define Y_MIN_POS 0
#define Z_MAX_POS 180
#define Z_MIN_POS 0
metalskin
Post by metalskin » Mon Dec 28, 2015 9:38 am
I am still a bit confused as to which firmware to use on my printer?
I have the Geeetech Aluminum Prusa I3 3D Printer kit
http://www.geeetech.com/geeetech-alumin ... p-944.html
Thank you
Mark
Post by Mark » Mon Dec 28, 2015 4:07 pm
use this one:
pccase
Post by pccase » Fri Jan 08, 2016 1:02 am
I have the prusa I3 pro c Dual Extruder Acryl. I delete my firmware :( . When i download here the Firmware i have a temperatur problem in the sketch.
What can i do?
Build-Optionen wurden verändert, alles wird neu gebaut
temperature.cpp: In function 'void manage_heater()':
temperature.cpp:665: error: unable to find a register to spill in class 'POINTER_REGS'
temperature.cpp:665: error: this is the insn:
(insn 98 97 100 4 (set (reg/v:SF 103 [ pid_input ])
(nil)))
Locked
Users browsing this forum: No registered users and 7 guests
