geeetech prusa I3 x extruder not heating up
liltroy85
Post by liltroy85 » Wed Sep 30, 2015 1:39 am
I have a prusa I3 x and i cannot get the extruder to heat up. It doesnt go past 32 degrees celcius.
Sherry
Re: geeetech prusa I3 x extruder not heating up
Post by Sherry » Thu Oct 01, 2015 10:06 pm
hi,please see if those three red toward heating cable connector leds are lighted up or not.
Manually heat up the hotbed and extruders, if the LED lights under the hotbed and extruder slot are lighted up, then the mosfet that controls the heating is good. next,please measure the resistance of two end of heating cable,it's resistance is about 3.6 ohms.
liltroy85
Post by liltroy85 » Fri Oct 02, 2015 1:36 am
computer board
no red leds?
liltroy85
Post by liltroy85 » Sat Oct 03, 2015 1:05 am
i dont see any red leds lighting up and i have 3.3 ohms across the heating cables. before i was able to manually heat the hotbed up but not the extruder. now neither will do anything.
lcd reading error mintemp
computer board
Mark
Post by Mark » Sat Oct 03, 2015 9:11 pm
hi, there's two places to check:
1) you have connected the extruder heating wire to the wrong place, it should be the first one;
2) the thermistor of the extruder1 is open circuit, please check the wires, see if not correct connected
Users browsing this forum: No registered users and 7 guests
