Problems on my geeetech i3B
furniturecreations
Post by furniturecreations » Sat Jul 04, 2015 1:25 am
:( 1)The X, Y and z axis do not work on (-) they only go forward (+), 2) the extruder goes up 4 mm when starting printing separating from the bed, 3)After doing the configuration on Slicer, when I start the printing, the extruder goes to the right(+) and tries to go out of the bed making the belt run, when I look at the position on the X and Y axis it is like 1400 both ways even do the bed is only 200 x 200, I did check all the settings, what am I missing? Help please!!!!
Sherry
Re: Problems on my geeetech i3B
Post by Sherry » Sat Jul 04, 2015 8:49 am
hi,you try to check if the wire is connected correctly especially the endstop wire.Maybe the port of endstop is in poor contact.
furniturecreations
Post by furniturecreations » Mon Jul 06, 2015 1:55 am
Hi, the connection prongs for the end stops are 3, Sig, (+) and Gnd., I do have all of them on their respective (+) and Gnd. Is that correct?
Sherry
Post by Sherry » Mon Jul 06, 2015 2:12 pm
furniturecreations wrote:Hi, the connection prongs for the end stops are 3, Sig, (+) and Gnd., I do have all of them on their respective (+) and Gnd. Is that correct?
Could you take some photos and let me check.Or please refer to the link(step 6).
link: http://www.geeetech.com/wiki/index.php/ ... tion#Step6
furniturecreations
Post by furniturecreations » Wed Jul 08, 2015 12:31 pm
These are the pictures of the end stops and the connections on the Sanguinololu board
Sherry
Post by Sherry » Wed Jul 08, 2015 2:01 pm
hi,you connect the endstop wire to wrong slot,the wire should connect to "sig" and "-".please see the picture where i mark a red circle.
furniturecreations
Post by furniturecreations » Wed Jul 08, 2015 2:39 pm
I will try that thanks.
Users browsing this forum: No registered users and 11 guests
