I have a Acrylic Geeetech I3 Pro B With GT250 control board & A4988 motor driver,
I set up every thing , & tested....X,Y Z motor work fine,but Extruder motor not working..
temperature of extruder ..check
spring tight ..check
motor driver.. check
plug extruder motor wire to x motor slot.. check
Exchang extruder motor wire with x motor wire.... check
motor driver voltage between 0.9-1V....check
I have try all this ,but still not work....
What should I do ??
Please Help......
Thanks.....
Extruder Motor Not working...
Re: Extruder Motor Not working...
Have you raised the temerature of extruder?
Is the extruder motor moving with no filament when it's connect to extruder mtor slot?
Yes...temperature 210..zhangxueyou wrote:Have you raised the temerature of extruder?
No...Extrude motot not move with Or without filament...when connect..
Yes, tempreture in 210,zhangxueyou wrote:Have you raised the temerature of extruder?
The motor not moving with filament or no filament when connect to extruder motor slot.....
Please Help.....
hi ,you try to check the subdivision of stepper motor.
- the subdivision of stepper motor
- 2-2.jpg (27.31 KiB) Viewed 16314 times
My is jumper inside....Being check , all okEric wrote:hi ,you try to check the subdivision of stepper motor.
- 2015-07-04 13.43.11.jpg (228.12 KiB) Viewed 16307 times
I am having same problem and have looked everywhere for solution. No email back from tech support yet.
Hello.
I have the same problem.
All motors operate in addition to the extruder
help me please
help me please
Hello.
help me please
help me please
Dear friends
please try the following ways to solve the problem.
1.the extruder will move until the temperature was raise to 180 degrees for PLS,240 degrees ABS.Please check whether the extruder is heated up.
2.please swap the driver board with x-axis,if x-axis is working,the driver board is good.
3.please connnect the motor wire of the extruder to x-axis .if working,the stepper motor is good.
4.please re=download the firmware.Please refer to attachment.
If all above methods do not work,please contact the customer service.
- PI3B-GT2560-single extruder.rar
- (268.74 KiB) Downloaded 595 times
