Dismantle extruder not heating
bernat
Post by bernat » Tue Dec 29, 2020 5:50 pm
Hi guys
I had to disassemble the extruder to see why it was not heating. I have seen that the extruder cables were out of the green strip, but I don't know where to put them.
Can you tell me?
Thank you
Delores
Re: Dismantle extruder not heating
Post by Delores » Tue Dec 29, 2020 7:29 pm
I recommend first removing the nozzle. Then,from the top, hold the drive gear open and gently work the drill bit down, removing often to clean off debris. If the bit is long enough, sooner or later it'll project out the hole where the nozzle fits. If not, gently work from the bottom up.
MyGroundBiz Login
bernat
Post by bernat » Tue Dec 29, 2020 7:55 pm
I have everything disassembled but the estruder cables do not know where they go?
WhatsApp Image 2020-12-29 at 12.50.00.jpeg (249.59 KiB) Viewed 5626 times
SibiVikki
Post by SibiVikki » Tue Mar 09, 2021 9:25 pm
I was able to remove the filament and went to again load. The process started UFABET but again the "heating" stopped at slightly past half.
