TMC2208 / 2209 VREF
gio@dkonline.be
TMC2208 / 2209 VREF
Post by gio@dkonline.be » Fri May 15, 2020 8:06 pm
hi all, geeetech say:
X and Z axis 1.1 V - 1.2 V
Y axis 1.35 V
and suggest use TMC2208
This mode need motor rotation invertion with motor tool.
Put big cooling radiator in TMC and motor
After 10min test, vref is too hight, motor burn
i think geeetech dont have tested vref.
The calculed value by myself based from motor value is:
X and Z: 0.7v
Y(not fount real motor irms): work fine with 0.95V no overheating and no loose step @ 60mm/sec max
E1 E2 E3: 1.20v
this calculator give same value of me
https://mak3r.de/stepper-driver-current ... e85bd-9d35
Re: TMC2208 / 2209 VREF
Post by William » Mon May 18, 2020 10:24 am
Sorry,generally, the voltage of TMC2208 is 0.7-0.8.
gio@dkonline.be
Post by gio@dkonline.be » Mon May 18, 2020 3:28 pm
hi William
why geeetech give me these values, its verry dangerous!!!!!
it's not professional!
it only took 3 min for my motor cooling radiator to take off !!!!
technicians are idiots ???
I told them it was too high voltage but they confirmed that I should use these values!
X and Z is 1000000% 0,7V maximum (calculed value)
for Y idont know the real irms electric value, the motor description say 1a max but its fake, with 0,7V he loose step, with 1V its to hot, with 0,95v i think is good but maximum speed 55mm/s
for E1, E2, E3 1,1v - 1,2v is good (calculed value 1.2V)
geeetech doesn't have good technicians who really know their job? they only have sorcerer's apprentices who say anything to customers.
it's really not serious.
If an unprofessional user tests these values ​​without paying attention he could set fire to his house !!!
Post by William » Mon May 18, 2020 3:54 pm
I am very sorry for this.
gio@dkonline.be
Post by gio@dkonline.be » Mon May 18, 2020 4:03 pm
you shouldn't be sorry.
you have to test what you say to customers before.
now i will have to replace the engine of the X which is making noise because it has overheated
i do make a order to website....
gio@dkonline.be
Post by gio@dkonline.be » Mon May 18, 2020 4:06 pm
a friend have make a little web site to help you
look
https://mak3r.de/stepper-driver-current ... alculator/
Post by William » Mon May 18, 2020 4:30 pm
Thank you for sharing!
KriKri854
Post by KriKri854 » Thu Jun 25, 2020 9:44 pm
I had also problem with overheating and I think one motor is also dead as knocking sound.
I've set X, Z to 0,65V and E0, E1, E2 to 0,65V Y also 0,85V.
I did test print but not 100% ok and very slow. I'm going to run some further tests.
What are you're final Vref settings ?
