LCD display problem
Re: LCD display problem
Post by William » Tue May 12, 2020 11:22 am
My picture may be a little difficult to understand. :lol:
The following interface is used to burn firmware. The above interface is used when printing after burning.
alexy34
Post by alexy34 » Tue May 12, 2020 11:28 am
the pin on the burn connection A B C D should be connected on witch pins on the st-link ?
Post by William » Tue May 12, 2020 11:33 am
Like this:
af150a3082d184d64d293fdedb9e0421.zip
(2.27 MiB) Downloaded 353 times
alexy34
Post by alexy34 » Tue May 12, 2020 11:47 am
connection ??
KriKri854
Post by KriKri854 » Thu May 14, 2020 1:45 pm
I’ve similar problem on my A30T. I’ve put the system directory of the 30T UI.zip file (completed translated version that I found on this forum) on a directory on a that card and inserted this sad card in the slot of the lcd. I’ve read this on the forum but after doing that the screen was black.
Did I do something wrong?
Do I have to copy the files in the system directory on the Ed card or simply the directory itself?
Thank you.
KriKri854
Post by KriKri854 » Thu May 14, 2020 2:47 pm
Can you send me the files to reflash lcd and procedure?
alexy34
Post by alexy34 » Thu May 14, 2020 10:20 pm
I haven't solved my problem yet, my screen still black.
I thing the only way to slove this problem is to connect the lcd screen to a ST-LINK emulator directly, but i don't know how to connect the wires.
Post by William » Fri May 15, 2020 2:19 pm
Sorry, we've sent out the screen
KriKri854
Post by KriKri854 » Tue May 19, 2020 5:17 pm
OK. Is it possible to test to update the actual screen with SK-link to see if it still works?
I've received the firmware but I do not know the pin connections. Is it same as on GTM32 motherboard?
Post by William » Tue May 19, 2020 6:12 pm
Which pin is connected to provide photos?
