Hey everyone
I’m getting close on getting the benchy perfect. Would anyone have any idea on what is causing these marks on the side?
Marks on side of benchy
- 7E7D2260-D462-4397-9388-0EF1EA1718F1.jpeg (534.49 KiB) Viewed 4314 times
Re: Marks on side of benchy
Hi, Are you referring to the trace on your bottom?
You can try to adjust the hot bed,
Do not print too fast.
The little marks on the side. It was hard to capture on camera. Thanks!
Hi, You can check the esteps on the screen,
Then see if your machine is loose, you can do it
Fastening treatment.
it is probably un-aligned joints
A10 Slic3r profile: here
