Printer issues Need g-code test print
ericarenee
Post by ericarenee » Sat Nov 30, 2019 12:10 am
Hi..
I am having a strange issue with geeetech a20t.
Is there any 3 color g code printable test for this printer (small quick printable item would be best) NOT A COLOR MIX OR BLENDING..
A 3 SOLID COLOR ITEM post sliced for this printer..
My ISSUE Is explained here
viewtopic.php?p=104417#p104417
I am kinda at the end of my Testing and assuming there is a firmware flaw in this printer that i am apparently the only one in the Universe owns
I found a fix for this issue...Someone from another forum the issue is the g-code is telling the machine to turn off the heaters to early..
Re: Printer issues Need g-code test print
Post by William » Mon Dec 02, 2019 11:55 am
Hi, ericarenee.
thanks for your feedback. I will ask and give your answer.
AllAroundTechy
Post by AllAroundTechy » Sun Dec 15, 2019 2:45 pm
Are you using Cura/ S3D/ MeshMixer for your slicer? I've noticed that most of the slicer programs try to start cooling down the extruder too fast when you get to 98% of the prints completion. In Cura this setting is found under Material>Final Print Temperature and making that the same as my "Printing Temperature" I'll never understand screwing up a print in the last few layers for the sake of cooling the print head quicker.
I can send you the gcode file for a 3 color model if needed. Just let me know.
gizmonic
Post by gizmonic » Fri Dec 27, 2019 1:40 pm
I've got an A20T and using Cura 4.4.1. I was having the same issue, and the post processing fixed it for me. Thanks ericarenee for that help!
Oli99959
Post by Oli99959 » Mon Apr 06, 2020 12:46 am
I am also looking for a sample G-code. The one provided on the SD card does not print good and also it is very big, so it takes a long time.
Would anyone have a small G-code sample for the A20T so that I can check my printer is working fine please?
Cheers,
Oli.
lmcmulle
Post by lmcmulle » Sat May 30, 2020 6:31 am
+1 it would be awesome if Geeetech posted some sample test models for download to act as a reference for mixing, multi color, etc. just like 2 or 3 different versions of the benchy or whatever, but straight printable gcode specific to the a20T and say generic PLA.
Post by William » Tue Jun 02, 2020 9:56 am
Hi,here is the A20T test model:
A.rar
(5.7 MiB) Downloaded 102 times
Users browsing this forum: No registered users and 19 guests
