Installing TMC2208
Le_zOU
Installing TMC2208
Post by Le_zOU » Mon Jan 21, 2019 5:10 pm
In pictures....
Carefully remove the ribbon cable from clips
Pay attention to GND pin on old and new drivers
Insert the driver first then only attach the heatsink, it's easier
I had to remove the 24V fan because the new drivers have a bigger heatsink so there is not enough clearance for the fan.
unclip ribbon cable and remove 4 screws
View without cover
Close up of factory drivers(note GND pin at bottom)
1 driver removed
Check of GND pin location on new and old drivers
2 new drivers installed
Top rank of drivers have GND at opposite location
All new drivers installed (be carefull that the wires don't push away the heatsink)
Board screwed back in place
24V fan removed
Cover and ribbon cable back in place
pepgra
Re: Installing TMC2208
Post by pepgra » Mon Jan 21, 2019 6:49 pm
Thanks yesterday I did this process, This is important:
1) The colors of the drivers are changed, you do not have to follow the color model, you have to follow the model of the pins
2) Just change the direction of the engines in Marlin.
Le_zOU
Post by Le_zOU » Mon Jan 21, 2019 6:54 pm
Correct, I edited the post with decription of pictures, I posted the pics from the phone so it was easier :p
Le_zOU
Post by Le_zOU » Tue Jan 22, 2019 2:40 am
Note, if you do not want to get rid of the FAN, I suggest printing this board cover:
https://www.thingiverse.com/thing:3322209
davesatu
Post by davesatu » Mon Feb 11, 2019 12:18 pm
Thanks to all for a much needed post.
For me there are 3 more important issues to consider.
1. All TMC2208's I have used (currently ver 1.2) say to remove the 3 jumpers under the A4988.
This is not mentioned and
2. Running this rig without a fan would be inviting trouble. Let's leave it at that.
3. The TMC2208 will benefit in operation from as much cooling as possible.
I also have put the original heatsink as well on the chip side but have not tried this in the A20M.
pepgra
Post by pepgra » Wed Feb 13, 2019 2:45 am
I have installed them and I have not changed any jumpers
Post by William » Mon Feb 18, 2019 10:46 am
Vert is correct.
You can remove the jumpers#3 off.
ktown1900
Post by ktown1900 » Thu Dec 19, 2019 2:38 pm
I have installed my tmc 2208 and inverted the direction of xyz axis.
When i move y it works correctly. Z and x doesn‘t do anything. Also my 3dtouch is already on.
Can you help me?
Post by William » Thu Dec 19, 2019 2:47 pm
Hi, Whether you can move the x / z axis normally without changing the driver board,
You can exchange the Y-axis motor cable with the motor cable that cannot be moved (the position of the motor cable port on the motherboard is not exchanged), check whether it can move normally, and determine whether the broken motor cable is causing this situation.
ktown1900
Post by ktown1900 » Fri Dec 20, 2019 5:17 am
Y and Z is now working correctly. Is this perhaps a Problem of the new tmcs?
