Color mixing software for multi-mixing printer
dtouton
Re: Color mixing software for multi-mixing printer
Post by dtouton » Fri Nov 15, 2019 10:21 pm
The Mac version doesn't work with Catalina !
An update please
Post by William » Mon Nov 18, 2019 9:08 am
An update please
Hi, Can you open the color mix when you use this system?
Can you describe your situation specifically?
dtouton
Post by dtouton » Mon Nov 18, 2019 10:45 pm
Catalina needs 64 bits applications, I thing it's the problem
Capture d’écran 2019-11-18 à 15.44.07.png (100.06 KiB) Viewed 13317 times
FeckDej
Post by FeckDej » Wed Nov 27, 2019 2:39 am
You need to run a chmod command in the terminal in order to be able to open the app.
Locked
