MeCreator 2 - X Motor very hot!
redirect303
Post by redirect303 » Sat Jul 06, 2019 5:00 pm
I just noticed now whilst printing, the X-Stepper motor gets extremely hot! (I measured 56 degrees C, compared to the Y motor which was 36 degrees C)
NOTE: The above is the EXTERNAL TEMPERATURE! - inside the motor casing could be considerably hotter!!
Also, printer is new (less than one week) !
Indeed the printed piece has a long rectangle shape, with longest side aligned on X, so I can expect more work for the motor on X direction.
Still, it worries me because I don't know the safe temperature range for this motor.
If the voltage is not right, I'd welcome some assistance here (never dealt with a printer before, I might require some extensive explanation)
Please advise.
Re: MeCreator 2 - X Motor very hot!
Post by William » Sat Jul 06, 2019 5:14 pm
Hi, you can try to turn the drive board voltage down to view
Clockwise adjustment increases and counterclockwise decreases.
redirect303
Post by redirect303 » Sat Jul 06, 2019 5:22 pm
What value should be the voltage and between which terminals to measure? I see there are 4 wires entering in the motor.
Thanks.
Post by William » Sat Jul 06, 2019 5:25 pm
HI,The picture shows the driver board on the motherboard. You can try to adjust the voltage of the driver board to reduce the heat of the motor.
redirect303
Post by redirect303 » Sat Jul 06, 2019 5:38 pm
I understand that...but HOW MUCH to reduce it? Which voltage (between which pins that voltage has to be measured)?
If i turn that potentiometer, i will not know how much I changed the voltage, unless I can measure it.
The diagram says voltage should be between 0.8 - 1.2V, but it doesn't say between which terminal it has to be measured. I see the black line drawing coming from the GND terminal, but the red line drawing goes to the potentiometer... I hope I am making sense.
Post by William » Sat Jul 06, 2019 5:42 pm
Hi, the position measured is the position marked on the graph.
redirect303
Post by redirect303 » Sat Jul 06, 2019 5:53 pm
I am not sure I understand what the diagram shows ... because the red line goes in the center of the potentiometer, which normally is just a bushing (the rotation point). So, if one terminal is the GND terminal, which is the other terminal?
Please check the attached image, it explains what I'm trying to say.
Stepper Driver_Notes.jpg (64.94 KiB) Viewed 1149 times
Post by William » Sat Jul 06, 2019 6:05 pm
Yes and you can try it. :D
redirect303
Post by redirect303 » Sat Jul 06, 2019 9:39 pm
I'm sorry, this is not very helpful at all... In fact you either don't understand my question, or don't care much. Either way, your latest answer make no sense whatsoever. I am sorry that I had to say this :(
Post by William » Mon Jul 08, 2019 9:04 am
Causes caused by overheating of the motor 1. The voltage of the drive board is too high;
                                             2. Insufficient heat dissipation;
                                             3. The temperature inside the house is higher than room temperature.
Users browsing this forum: No registered users and 0 guests
