Geeetech A10 problem solving instruction?
EthanElijah
Post by EthanElijah » Wed Jul 01, 2020 8:19 pm
The extruder step motor moves back and forth, but the filament does not advance.
Disassembled, the motor shaft moves smoothly.
I have exchanged it Speed Test essay writer for the one on the Y-axis but the problem persists.
For this reason, no filament comes out and I cannot print.
Model Geeetech A10
Marlin 1.1.8
2017-12-25
Board info
GT2560 V3.1
FW ver 1.5
HW ver 5.00
Regards,
gopher
Re: Geeetech A10 problem solving instruction?
Post by gopher » Thu Jul 02, 2020 12:43 am
Hi!
The hotend is clogged, you should clean the throat and assebmle or clean new nozzle.
Just yesterday i've got this problem with petg, removed the nozzle with new one and all is ok!
doistons
Post by doistons » Sat Jul 04, 2020 2:52 pm
I have almost the same problem: my printer cannot extrude well. I had to change the hotend because I mashed the nozzle trying to get it out and I failed. :(
If the problem is the extrusion of the filament without being in the hotend, the problem may be the spring of the gear that pulls the filament, it is the same that is triggered when you pull the lever to place the filament in the extruder. It may be too tight or too loose. If you look at the left side of the extruder, you will see a screw. Use it to adjust the spring.
HelloMrBirdie
Post by HelloMrBirdie » Sun Jul 12, 2020 3:21 pm
If it isn't a clog then you need to calibrate the amount being pushed through the extruder. https://all3dp.com/2/extruder-calibrati ... y-steps-2/
