I moved the printer and now the bed shows 112c when idle (and does not change when I unplug it from the main board) and and the thermister for E1 (wired into extra pins) now also shows -14c. The thermisters on both the bed and E1 are both ok and were working before I moved the printer. I have checked the connections with a multimeter and I am getting correct resistance values on both thermisters, but the board is not reading them
Since I havn't changed firmware or done anything at all in software, i'm thinking the board itself is faulty. Is there anything in common with the bed and pins (i'm having trouble finding the schematic I originally used. It's the 2 rightmost pins on the connector that normally only has a few wires on it, I had to add extra pins to it)
A10M - bed and E1 temp suddenly stopped reporting
Re: A10M - bed and E1 temp suddenly stopped reporting
Hi, If you unplug your hotbed cable from the motherboard,
If the temperature on the screen is still high,
The motherboard may be malfunctioning.
For the schematic diagram of the motherboard, you can refer to this: https://www.geeetech.com/download.html?download_id=43
One of the major contacts is found for the positives for the men in the area. The blog of the https://www.paperwritingpro.com/our-ser ... erm-paper/ for allies. The change is fit for the behest of the goals for the approval of the terms for signs.
3D printers are very important to use. As we know, in the present time when children want to submit their work they want images more beautiful and focused which can only be got through Murphy Beds Arizona digital printers.
Thanks for sharing this useful information with us. By the way, I am searching for the greenhouse business plan online. Can anyone over here please help me?
The Mandalay Sound is likewise awesome. Try not to be Buffet near me tricked by the totally delightful Aria Buffet; your eyes will adore the cutting edge, breezy, open, agreeable, excellent environment yet your taste-buds won't partake in the food anyplace nearly so much.
If your heating or cooling system will run but room temperature is too hot or too cold.
