Starting a print mid print
Re: Starting a print mid print
Post by William » Thu Dec 12, 2019 9:40 am
Hi, Whether your extruder motor can run normally.
Regarding whether the nozzle is clogged, you can try to heat the nozzle temperature to 200 ° and then push the consumables.
See if the material can be discharged normally.
If your model is mixed color, you can check what your ratio is.
